Resultat 1 till 5 av 5
Ämne: ELM327 with Torque OG9-5
    maj 2021
    Hello,
    I'm trying to connect to the ECU using my cheap ELM327 via bluetooth but for some reason it says it could only connect to the ELM327 but not to the ECU. It tried a bunch of different preset protocols but in vain.
    The car is a 2007 9-5 Kombi.
    I'm not sure if there's a specific protocol that isn't on the list that I'd need to specify or if there's a maneuver to do before it's activated?
    Does the key need to be on the ON position? Does the car need to be running?
    If anyone had this issue and managed to resolve it, please share some tips
    Thanks in advance!
    Two problems that been seen in the past, the specific ELM327 box you are using is not supporting all protocols, and some parts are missing for the protocol your Saab is using, or one or more of the sockets in the OBD2 connector has been pushed in.
    Assuming you have ignition on and you don't have any immobilizer problems.
    maj 2021
    How do I know if I have immobilizer problems? I had a stöldskydd ur funktion indication but it went off after a while.
    Thanks!
    Citat Ursprungligen postat av logicbloke Visa inlägg
    OK. It should work.
    Yes
    No
    Some tips:
    1. Try to disconnect and reconnect the adapter with the ignition on.
    2. Check the OBD2 connector in the car for the problems described above by Långmilare.
    3. Check the OBD2 connector in the adapter in the same way.
    4. Try another ELM327 adapter. The problem may very well be there. All adapters are not the same...
    5. Try your adapter in another car. Preferably another og9-5
    In any order yo find convenient.
    If your car runs, you don't have that.
  1. kontroll av turbo laddtryck mm Torque?
    Av 74anders i forum Motor och motorstyrning
    Senaste inlägg: 2016-12-01, 21:09
  2. Oerhört spårig / torque-steering / vibrationer i bilen (9-5 SC AERO) -07
    Av Eken92 i forum Chassi, bromsar och transmission
    Senaste inlägg: 2015-04-15, 00:31
  3. Torque Appen, F'låt en amatör
    Av LasseH i forum Motor och motorstyrning
    Senaste inlägg: 2014-10-28, 22:38
  4. Hjulvinkel som minskar torque steer och spårkänslighet ?
    Av Mr_Nitro i forum Chassi, bromsar och transmission
    Svar: 15
    Senaste inlägg: 2014-06-12, 09:14
  5. Torque OBDII Inställningar
    Av Dadid i forum Ljud och elektricitet
    Senaste inlägg: 2013-08-13, 09:37
