Resultat 1 till 2 av 2
Ämne: 900 s non turbo 5 speed manual transmission
    okt 2017
    Hello Everyone,
    I'm wondering if there's any other location on my 900 s manual trans that I can fill the trans from. My fill bolt of course is stripped out and won't budge and yes I tried to remove the fill bolt first.
    Any Idea , Suggestions would be appreciated,
    Thanks,
    I didn't find the right solution from the internet.
    Senast redigerat av HeRmAN den 2017-11-22 klockan 13:16. Anledning: Removed links
    Östersund
    You can fill oil in the primary gear housing.
    Just remove cover in top of the front cover and fill oil that way.
  1. 900 2,3T - 505hk/690Nm Nordic Extreme R
    Av airflowfredde i forum Projekt
    Svar: 1864
    Senaste inlägg: 2021-02-05, 08:59
  2. Goodwood - Festival Of Speed
    Av Myggan i forum Motor- och trafikrelaterat
    Senaste inlägg: 2009-07-22, 18:58
  3. Autobahn - Vad er din max speed?
    Av hel i forum Allmänt
    Senaste inlägg: 2006-08-03, 17:28
  4. Speed warning?
    Av glassguran i forum Ljud och elektricitet
    Svar: 24
    Senaste inlägg: 2006-03-17, 13:18
