Ämne: Recomended oil and liquid cooling system 900 2.0i 8v
    nov 2017
    Luleå
    On Saturday I will pick up a 900 from Arjeplog and drive back to Luleå. The car was not running for 6 months so I want to have with me a can of oil and liquid for the cooling system just in case. Here we already have snow. Which oil and cooling liquid should I use. Any other recomendation.
    Thank you
    Steg 5 Mr.Os avatar
    nov 2004
    ja
    I guess you understand swedish, since you managed to find the correct section for your question. By the way, please have a look at our international (=english) section....
    21 Motorolja Kvalitet:
    Saab Turbo motorolja alt motorolja som minst uppfyller kraven enl. API SG och CCMC G4/G5.Oljor enl. dessa kvaliteter innehåller för motorn lämpliga tillsatser. Vi avråder från ytterligare tillsatser.
    Viskositet:
    SAE 10W-30, 10W-40, 5W-30 alt 5W-40. Om dessa kvaliteter inte finns tillgängliga kan olja med viskositet 15W-40 användas, dock ej vintertid. Vid användning av 5W-oljor ska dessa vara av hel-eller delsyntetisk typ. I länder där temperaturen aldrig understiger +15-20 C rekommenderas olja med viskositet 15W-50 eller 20W-50.
    Or just check out this site...
    http://www.saabnet.com/tsn/faq/manuals/
    And read the fine manual!
    Steg 5 Mr.Os avatar
    nov 2004
    ja
    It has been pointed out to me that it is a good idea to provide the answer to your question not only in the swedish language, but also in english. Please, enjoy!
    According to the Saab 900 1994 owner´s manual:
    Engine oil Quality: API Service SG and CCMC G4/G5
    Viscosity: SAE 10W/30, 10W/40, 5W/30, 5W/40; if these viscosities are not available, 15W/40 may be used, except in cold weather.
    Oil capacity (including filter): 4.0 US qts (4 I)
    Oil filter: Saab Long-life
    Engine coolant volume including heating system: 10.5 U.S.qts (10liters)
    Antifreeze: Saab PIN 02 08 991 (BASF G-48 ) Canada PIN 993088
    Ordvitsare
    feb 2007
    Arjeplog at the polar circle
    It is very slippery on the roads, especially from Arvidsjaur to Älvsbyn, so studded tires is almost mandatory..
    nov 2017
    Luleå
    Thank you,
  1. PID 03 Fuel System Status (Fuel System 1 - open loop)
    Av gul93SE i forum Motor och motorstyrning
    Senaste inlägg: 2017-10-02, 19:25
  2. Turtle ICE Synthetic Liquid Shine någon som testat?
    Av aeromagnus i forum Bilvård, utseende och styling
    Senaste inlägg: 2008-05-23, 10:35
  3. APC system.
    Av sodastream365 i forum Motor och motorstyrning
    Svar: 12
    Senaste inlägg: 2006-07-03, 23:42
  4. cooling fan
    Av Pepsi i forum Ljud och elektricitet
    Senaste inlägg: 2005-06-18, 20:06
