Resultat 1 till 3 av 3
Ämne: Boostpressure too high NG93 1,8t bsr
    Hello
    Boost pressure ( stage 1) peaks 3-5th gear around 1,6 bar and i think that it`s too much. If i return standard software, pressure is what it should be ( around 0,5 bar).
    Any ideas why? Ok it`s very warm weather here in Finland ( 26-28c), but still...
    Br
    Aki
    feb 2006
    Re: 93sc 1,8t bsr boostpressure too high ( sorry in english)
    Hi Aki
    What stage (from BSR) do you have? Start by check all rubber tubes/hoses - they should be soft, if not, replace them. Pay extra attention to the hoses near turbo.
    1.6 bar sounds a little to much. Does it run smoothly?
    Citat Ursprungligen postat av colan
    Hi Aki
    Hello
    Car runs smootly, except clutch starts to slip. We propably found the reason, why boost pressure is so high. We did some logging with Tech and came up, that atmosphere pressure reading ( ecu) is 39kpa. As far as i know, it should be 100kpa ( 1 bar).
    Well only problem is now, where the signal comes??? My 03-04 sensor near fuel pressure regulator, but my06 there is only empty space.. Wis Don`t know??
    Anyone???
    One guess is that it comes from Evap pressure sensor. But it`s only guess until some facts cames from Saab. Hopefully
  1. DIY RCA i High-end silver
    Av Mma fighter i forum Musikhörnan
    Svar: 0
    Senaste inlägg: 2017-02-27, 06:11
  2. Erfarenheter av SBS high carbon bromsskivor?
    Av kIM0h i forum Chassi, bromsar och transmission
    Senaste inlägg: 2011-12-19, 02:13
  3. Vart tog High octane vägen?
    Av Micke_Persson i forum Off Topic
    Svar: 0
    Senaste inlägg: 2009-10-31, 10:55
  4. Wössner High Performance Pistons
    Av ducati1000ss i forum Motor och motorstyrning
    Senaste inlägg: 2006-09-11, 09:23
