Nån som är påläst vad gäller Xenon D1S lampor, vill köpa nya till min -06:a och stötte på en varnings text hos Xenonkungen vad gäller serien på lampan, de säger att serie 141 eller 142 skall användas. Vidare googling finner jag nedanstående engelst text, tydligen så har 141 o 142 ingen spole som verkar slå sönder styrenhen (LCM)till just dessa årsmodeller.
Följdfrågan blir att jag tänkte byta till en kallare lampa philips har än den 4200:an som sitter standard (141), dessa har inte serie 139-142, har dessa då spole eller inte, vad gäller andra fabrikat kör de med spole?
Xenon Lamp Control Module
On the 2005-06 Saab 9-5, repeated need for replacement of the xenon lamp ECM/AHL may be caused by mis-matching the xenon bulb with the ECM.
The supplier was changed from Osram to Philips. During the supplier change, a design change of the bulb eliminated a coil. This coil was shown to cause a voltage spike to the ECM/AHL during headlamp start up that would damage the ECM.
All xenon bulbs carry the same part number, regardless of supplier. However, the 10-digit serial number on the lower left hand side of the label (fig. 5) of the Philips bulb indicates whether the bulb has a coil or not. The digits in positions 5 through 7 indicate the coil situation.
A Manufacturer
B Number sequence location
Positions 5 through 7 of serial number, Coil/No Coil
139 or 140 Lamp has coil
141 or 142 Lamp has NO COIL
If the vehicle has a failed headlamp ECM/AHL, inspect the bulb serial number. Bulbs with the 139/140 sequence must be replaced with the 141/142. Only the Philips bulb will have this code/serial number.
TIP: The xenon headlamp ECM is the same module as the AHL.
