Sidan 2 av 2 FörstaFörsta 12
Resultat 21 till 27 av 27
Ämne: bonjour de france c900 airflows 87
  1. #21
    mar 2010
    Re: bonjour de france c900 airflows 87
    Thanks a lot for your feedback..
    In fact i said me that original crusch sleeve should be crushed .So i tapped on it for extended the sleeve a bit .I was at 18.80 when i removed the original and i put it at 19.10mm .I thought that the sleeve will "crush " again..But no ..Under 4 tonnes nothing .So i start solid sleeve at 19 mm . - 0.3 mm will not so hard to remove without machine .
    For the prelaod i do the test with string and tensiometer around the bearing housing .Normaly saab give 4.7 kg to 7 kg when you pull , but i have read that some people changed preaload for "heavier " use .Maybe it should be better to have a few more than 7kg , I suppose that it should be increase the gear oil temp .I put a temp sensor on diff plate for monitor and if i need , install oil gear cooling system.
  2. #22
    Östersund
    One of my old sleeves was 18,6mm and there was still a preload at that bearing.
    I have a new crush sleeve with a length of 20,1mm.
    To much preload is not good for the bearings. Maybe the bearing manufacturer can give any ideas ?
  3. #23
    Östersund
  4. #24
    mar 2010
    Thanks a lot saabaero for your info and link ..
  5. #25
    Citat Ursprungligen postat av SaabAero
    That's actually very informational site. It helped me a lot.
    Thank you.
  6. #26
    mar 2010
    some new about my gearbox ..
    I have finish the gearbox rebuilt , and upgarding .
    It s looks like this :
    What do you thinks about the gearbox front case ventilation port ??is it very important or not ??
    inside ,
    i put a solid crush sleeve , the good size for correct prelload is around 18.70mm
    thanks for your link saabaero ..
    I decrease the gap between selector finger , and forks by carring of material each side with mig .
    Stock i was at 0.60 mm gap decrease to 0.15 mm
    Final test on road wensday ..I will see what happened..
  7. #27
    Östersund
    Citat Ursprungligen postat av cece95
    You need a ventailation hole.
    If not, you will have a leakage in one of the axle sealings when the oil temperature goes upp and a overpressure builds up in the gearbox.
    All gearboxes have some kind of breating filter.
    Good idea to tighten the play in the shifting fingers. Hope it will work fine
  1. C900 webasto car heater
    Av Craig i forum International SAAB related talk
    Svar: 14
    Senaste inlägg: 2013-04-08, 21:07
  2. Swiss Police Saab turbo c900 - anyone have more details?
    Av saab_o_naut i forum International SAAB related talk
    Senaste inlägg: 2008-06-25, 14:21
  3. 81 turbo 8V c900 intercooler mod - cold-air intake ideas?
    Senaste inlägg: 2008-04-20, 05:53
  4. 'issues' with my 8V turbo C900...
    Senaste inlägg: 2006-04-27, 00:45
  5. Ignition and boost on Lucas c900!
    Av Saab-Daniel i forum Motor och motorstyrning
    Senaste inlägg: 2005-05-13, 23:13
