Resultat 1 till 7 av 7
Ämne: TO RAGNAR ... 99 which T5.5
    hello, i am kawaman, mostly actief on saabforum.nl
    and ecuproject.com
    i am a student in my 3de year profesional batchler car technologie and my major hobby and passion is saab Turbo...
    i have a 9000CSE which stage 3 and +- 255hp
    my daily car.
    i have a 9000CC turbo which i want to drive on circuit (zolder) i have 1 problem the original ignition su***! ...
    i a making 1.4bar boost... which fuel chip but the ignition dus not support this.. i have misfire and a lot of power loss...
    i want to put T5 on it...
    my question is if you would like to share your technical drawing of the parts you made to mount the crankschaft position disc and sensor on the B202 engine like in your 99 from 83....
    so i can duplicate tis for quickly mounting the T5 parts on the engine.
    here you can see my major project's :
    http://<br /> <a href="http://www.sa...&start=270</a>
    http://www.saabforum.nl/viewtopic.php?t=37551&start=45
    http://forum.ecuproject.com/viewtopic.php?f=20&t=903
    i am wachting tis 1 very well...
    this is my
    http://forum.ecuproject.com/viewtopic.php?f=20&t=1534
    grtz pieter
    ps i don't understand a word swedische ....
    Re: TO RAGNAR ... 99 which T5.5
    Hello,
    You and some others have asked about the drawing for my T5-installation brackets, and I really have nothing against charing them with you guys. Only problem is I need to find them... it's been a while, and I'm currently rather busy. I'll do my best to check again.
    Cheers,
    /Ragnar
    Citat Ursprungligen postat av Ragnar
    Hello,
    Cheers,
    /Ragnar
    ok!
    i'll wait .
    thanks all ready.
    grtz
    hey, its been a month, found them already ?
    grtz
    Emeritus
    Depending on what it looks like on the B202 in the 9000 (I've done a C900) you could make new holes and mount it directly on the pulley, that's what I did, works fine.
    And btw, Ragnar did it on a 99 which is more similar to a C900 than a 9000.
    mar 2010
    A b202 with di have the same disk than trionic 5.2 .So the modification will easy ..For t5.5 it s other way but you know this ...
    I didn t know what to do , put t5.2 or t5.5 ..In according with info on ecu project there is small differences but in final the same possibilities..There aren t 2.0 software for t5.2 but if you do special software you will need to remap for your hardware so it s the same in final...
    I can share you my software t5.2 for my classic..T5 head , b201 block , t16 acc , front ic , td04 -5 , 9000 fuel +rail 345cc ...It runs so after you will need some adjustments...I am in final adjustement but it seems push 220/250hp...(checked in afr ratio )
    hey,
    bin file would be great, i have the car rolling with T5.2 and a TE03-TE04 hybride turbo, 7250RPM, 1.6bar pressure, siemens deka 830CC injectors E85
    making 350bhp to 400
    but driving on public road sucks .... at wot its going great !!!
    hermans.pieter@live.be
    waiting on drawings and bin file thanks !
    i am building the next trionic conversted car this summer with T5.5
    grtz
  1. Hur gick det på LMS, Ragnar & Co ?
    Av Xmit i forum Allmänt
    Senaste inlägg: 2005-08-14, 12:20
