Som topic är detta möljigt utan för mycket jobb?
Saab 9-5 Aero -02 - http://www.garaget.org/?car=275939
Saab 9-3 2,0t -99 - Såld
http://www.saabcentral.com/~munki/te...r/sid_unit.htm
Upgrading the SID
A commonly asked question is whether it is possible to 'upgrade' the SID to a higher one. This is only really feasible if you are upgrading a SID2 to a SID3 - as the additional functions of the SID3 do not require further modification. If, however, the plan is to move from a SID1 to a SID2, then, in order to enjoy the the additional functionality, further work will be required to fit the extra sensors and this is usually too much effort and expense for the benefits that are offered.
tackar för svaret, men tror du man kan få igång några av funktionerna som tempen, black panel genom att bara koppla in den, får väl gå ut o testa annars, ta min sid2 o sätta in i brors med sid1
