Resultat 1 till 2 av 2
Ämne: B235R with B234 Pistons & Con. Rods
    I've been working on my 9-5 recently.. Got all the required parts
    As I'm working on the Engine I have used the 9000 Pistons with connecting rods on the T7 block ..
    The question is which Head gasket shall I use?
    Is it the 9-5 gasket P# 5960083
    or
    the 9000 gasket P# 9185695.
    Regards,
    I dont speak swedish, english only
    As far as i've understood from e.g Rickards project thread og9-3 cab 6vxl 432Hk you need to either use the T5 gasket or lathe away some material (1.1mm) from the T5 pistons if using the T7 gasket.
    http://forum.saabturboclub.com/viewt...588211#1588211
  1. 9000 2.3 turbo and ng900 2.3i crank and rods question.
    Av Saab900turboest i forum International SAAB related talk
    Svar: 0
    Senaste inlägg: 2011-10-15, 10:23
  2. Bästa mix av B234 och B235R motorn önskas
    Av PeterNacka i forum Motor och motorstyrning
    Senaste inlägg: 2010-02-16, 20:55
  3. Viggen B235R vs OG9-5 B235R i en OG9-3 Aero -01
    Av Per-Ola i forum Motor och motorstyrning
    Senaste inlägg: 2009-09-07, 16:14
  4. Wössner High Performance Pistons
    Av ducati1000ss i forum Motor och motorstyrning
    Senaste inlägg: 2006-09-11, 09:23
