Kikade på specen för TurboX:en.. och den har ju 345mm skivor
Men vad är det för ok som sitter på den?
Fram pratar jag om såklart!
/A
/A
Numera Golf TSi.
BMW 120 M -08! Såld
Klart att det är Hirschbromsar!
345mm Brake upgrade
Built for a situation tougher than racing. Rush hour.
Even very impressive-looking multi-piston racing brake system can suffer from overheated brake fluid when confronted with such mundane situations such as repeated hard braking and acceleration manoevers at speeds below 100km/h, when the limited airflow cannot cool the brakes adequately. The reason for this problem is that in a multi-piston design, a brake fluid line needs to be routed very closely past the hot brake disc to reach the outer pistons. This is of course not a problem when racing, when there is always enough airflow to cool the brakes, but for rush hour traffic, this can be critical.
Further, the stopping performance of typical racing brakes with adhesion-type brake pads is highly dependent on that the brakes are slowly heated to operating temperature before being used for hard braking. Cold and rainy weather will have a severe impact on the performance of such brakes. Again, this is acceptable on a race track, but not for the everyday driver.
Therefore, to ensure that with the new Hirsch Performance brake, the stopping power is always available when you need it and not just for a sunny day on the race track, Hirsch Performance has decided to use well-proven, deceivingly low-key single piston technology, and scale it up generously for optimal stopping and cooling performance. The caliper design and the brake pads chosen offer good performance both when cold and when hot, making this brake a truly reliable component for any situation. By using internally ventilated discs without grooves or holes, the brake noise level as well as the heat dissipation through the disc is optimised.
No compromises
Just like all other Hirsch Performance products, this brake upgrade is compliant with EU homologation requirements and is shipped with the necessary documentation. Service intervals remain unchanged. The small number of moving parts exposed to the hot and corrosive environment ensures excellent reliability and durability. Vehicles equipped with Hirsch Performance products remain covered by Saab Original Warranty.
art number
F590001100
Description
345mm (17") brake discs Single-piston fist frame caliper High performance road brake pads and 18" 6 spoke Design Wheels
http://www.hirsch-performance.com/ge...4-e78dd74fc51d
Hirsch å Hirsch. Just dessa 345mm bromsar som Hirsch har är baserade på Vectra OPC prylar. Så det är således standard GM hårdvara från hyllan. OKen till de sk. 9-3 Aero+ bromsarna på 314mm & Vectra OPC på 345mm ska vara i det närmaste samma. Bygeln som håller OKen skiljer då de behöver sitta olika långt ut från axelcentrum beroende på skivans diameter.Ursprungligen postat av Trued
