Tack gör hjälpen i denna tråden!
Jag bytte ut batterierna i helgen och felmeddelandet försvann! Hoppas att det fungerar i längden!![]()
Saab 9-5 kombi 2,0T 2002
Saab 9-5 2,0T 2000
Hello. I drive a 9-5 2.3t from 1999 and I have the same problem with the theft alarm going of randomly without the hazards flashing and the "service theft alarm" message in the SID. Last year, I changed the batteries from original 1999 Sanyo CR17335 to 2009 Sanyo CR17335SE. This worked fine for five months. Then I read about the capacitors and changed all three plus another set of two Sanyo CR17335, this time original CR17335 (not SE), new but made in 2005. This operation worked only for one weekUrsprungligen postat av PHermansson
It seems like, the more you try, things are getting worse and worse... Maybe its not the batteries, not the capacitors... who knows ? Maybe the transistors need a change...
Did you find a solution and finally manage to repair your siren ? I am sorry, that I can't write in swedish. Thanks in advance !
My siren has been working as it should for about 1,5 years. After I fixed the solder joints I haven't had a single false alarm. Open the siren, resolder the joints. Add solder where needed, check that the joints look fine.
See http://www.dummies.com/how-to/content/s ... g-101.html, it has pictures of good and bad joints.
Tack så mycket ! So I'll give it a last try... a new siren is quiet expensive (almost 350 Euro)![]()
Bytt baterierna två gånger i sirenen men det håller bara några veckor.
Använt rätt betäckning på batterierna.
Funderar nu på att byta till en ny/annan siren i stället.
Ni som gjort det vad har ni fått ge för en ny? å vart kan man billigast få tag på en?
9-5 Aero Kombi 00a
Bra på särskrivning
De är inte billiga.... att löda om den är i princip gratis.
Samma här, hoppas det håller, annars får jag prova att löda om lite..Ursprungligen postat av anflyg
That´s why they call us vikings..
Saab 9-5 2,3t -00
Jag provade först med CR17335SE, men "Service stöldalarm" kom tillbaka efter 2-3 mån. Det verkar som det är fel strömkapacitet på dessa, 1800mAh, till larmsirenen som gör att det inte fungerar...?
Original CR17335 är 1400mAh.
Däremot hittade jag ett annat batteri, som nyligen kommit in, på ELFA.
Panasonic Litiumbatteri 3.0 V 1200 mAh, BR 2/3A E2SP. Art.nr: 69-419-43, med lödfanorna som på originalbatteriet.
När jag granskade detta batteri närmare stod det även CR17335.
De är inte exakt lika i specifikationerna som originalbatteriet men bättre än CR17335SE.
Dessa batterier har fungerat i 6 mån nu men man kanske inte skall ropa hej ännu....det fungerar(och är en billig lösning) än så länge iaf!!
Saab 9-3X TTid4 -11
Hur kan lägre "strömkapacitet" vara bättre?Ursprungligen postat av Bream69
9-5 aero -02 kombi
Ja, det vet jag inte riktigt...Kanske beror det på att CR17335 batterierna är anpassade till kretsarna på kortet? Ett Litiumbatteri skall ju hålla i många år oavsett strömkapacitet...Bara de funkar ihop med övrig elektronik liksom...
Saab 9-3X TTid4 -11
Hmmm jag får iallafall inte ihop det. Men det kan ju vara andra skillnader mellan batterierna...Ursprungligen postat av Bream69
Mitt larm tjuter som f-n om man låser upp med nyckeln, men jag har ändå "service theft alarm" varenda gång jag slår på tändningen. Används batterierna som diskuteras här till att driva sirenen, eller har de ngn annan funktion? Dvs är det värt att byta dem, trots att larmet verkar funger, eller är det nåt annat fel på min bil, måntro?
9-5 aero -02 kombi
Jag måste nog göra ett batteribyte på min -04, och jag har då ett par frågor:
Fråga 1: Passar vilken sirénmodul som helst från en 9-5a på vilken 9-5a som helst (jag funderar på att köpa en bättre begagnad med skruvat lock och byta batterier på den istället för att hålla på och såga upp min limmade variant)? Behöver den nya giftas in?
Fråga 2: Om man helt sonika plockar bort modulen, kommer bilen att funka som den ska (bortsett från att larmet är ur funktion)?
Batterierna är väl backup ifall det vanliga batteriet tar slut.Ursprungligen postat av navarra
Tråkiga är ju när batterierna börjar ta slut så brukar ju larmettjuta också.
Så visar den bara service stöldlarm så kan det ju vara något annat fel.
9-5 Aero Kombi 00a
Bra på särskrivning
Bilen kommer gå som den ska.Ursprungligen postat av jellybear
enda är ju då att larmet saknas och att felmedelandet kommer upp.
om det är samma som på en 00a Men det lär det väl vara.
9-5 Aero Kombi 00a
Bra på särskrivning
Det är likadan siren i alla 9-5 og (98-10) och 9-3 og (98-02)
Min Svarta 9-5 AERO -00 http://www.garaget.org/?car=26131
Skönt, så kan jag ge mig på operation batteribyte utan oroa mig för att bli stillastående ifall jag har sönder sirenen under operationen.Ursprungligen postat av viggenmicke
Bra, då ska jag nog försöka få tag på en gammal siren (med skruvat hölje istället för de nya som har ett limmat hölje) ifall min batteribytesprocess inte lyckas.Ursprungligen postat av marasp
Jag ska till å byta de där jag med. Men de hade varit trevlig om bilderna hade funkat oxå på den här tråden.
Begagnade larmsirener hittar ni till exempel här
viewtopic.php?f=19&t=296939
Tradera.se
bildelsbasen.se och laga.se
tack. Nu vet jag hur den ser ut.![]()
hej jag har samma j...a problem som många andra här med att larmet börjar tjuta när det själv vill, service larm meddelandet har visats länge nu. har inte tid att fixa larmet än på ett tag så jag letade efter en tillfällig lösning och hittade en säkring i motorrummet som enligt säkrings schemat går till siren och ac. testade om larmet funkade när jag tagit väck den lamporna började blinka men inget tjutande från sirenen. kan jag köra med bilen så här tills jag fixat problemet eller kan det bli problem med några andra funktioner på bilen förutom AC:n
mvh Tobbe
Saab 9-5 2,3t -98
