The B202 non-turbo block and b202 turbo blocks have different part numbers -- does anyone know what the differences are? I cannot see any obvious differences between them.
Thanks!
Thanks!
Hi!
I think the difference are that the non-turbo block has a plug were the oil-return from the turbo is. And the pistons ofcourse...
Johan Carlsson#2661
Tech2 med Candi finnes
Ah, yes, pistons are different. :-)
Regarding the block itself, if the only difference between a turbo and non-turbo block was the oil return plug, would Saab have used a different part number?
I ask this question about the differences because I once read that the difference between the two is that the turbo block has higher nickel content. But I read this on the internet, and you know how that can be...
Cheers,
-Hans
PS By the way, nice car! Question about the manifold -- it looks like it's from a B212. I thought those were in the U.S. only?? Are they hard to get in Sweden? And there are no holes for vacuum lines. Did you plug them and put holes in the bottom?
Engine blocks are made of grey cast iron 0125. This is an internal standard but the standard is similar to swedish material standard SS 140125. The material contains no nickel. The exhaust manifolds possebly contains nickel though, and I would expect the turbo manifolds to be made of a more heat resistant alloy (possebly more nickel). But I have no material specs on the older manifolds, newer manifolds (such as Aero V6) are made of Si-Mo alloyed cast iron.
I think the only differences between the blockas are the ones mentioned by Johan-99T16. Saab used different part numbers for i and turbo blocks later too, although the blocks are based on the same casting.
Johan Carlsson#2661
Thanks for the information, Johan and Johan! :-)
