Resultat 1 till 2 av 2
Ämne: Felkod acc "Delen Finns ej" FIXAT
    apr 2003
    Hur kan man få en felkod på något som inte finns????
    Så här står det.
    B2380
    Circulation Pump. Short to B+
    Circulation Pump. Open Circuit / Short to Ground
    Fault symptoms
    Experienced cabin temperature is too low when compared to the set temperature
    Conditions
    The following conditions apply:
    • A short to B+ is indicated when the output for the circulation pump is activated and the voltage on pin 23 exceeds 6 V.
    • A short to ground is indicated when the output for the circulation pump is not activated and the voltage on pin 23 exceeds 6 V.
    • Measured every 440 ms and 5 consecutive measurements are required to set a diagnostic trouble code.
    • The diagnostic trouble code is cleared after the ignition has been turned on 20 times and the malfunction conditions have not been fulfilled.
    • When the diagnostic trouble code has been set the output is switched off.
    Detta är felkod 19 på acc,n.
    Jag har ingen sådan pump på bilen.
    Sitter inte ens stift i uttaget för Pin 23.
    9-5 -98 2,3 sedan.
    Heavy metal is the law.
    apr 2003
    Va antagligen fel programvara.
    Fixat med en tec2.
  1. Svar: 79
    Senaste inlägg: 2020-07-26, 16:15
  2. [LÖST] Kluckande, Skrammel, "Klapprande ljud" i framvagnen OG9-5
    Av asppie i forum Chassi, bromsar och transmission
    Senaste inlägg: 2010-06-19, 00:43
  3. [LÖST] Turbon laddar inte, men bilen går i övrigt bra OG9-3 T5
    Av Tobbe87 i forum Motor och motorstyrning
    Senaste inlägg: 2009-08-28, 17:14
  4. Hjälp CHECK ENGINE 9000 "FIXAT""
    Av saab9000cc i forum Motor och motorstyrning
    Senaste inlägg: 2006-03-28, 11:05
