Resultat 1 till 2 av 2
Ämne: Saab 9000 Strut Bar
    aug 2005
    Poland
    Saab 9000 Strut Bar
    Hello there,
    Does anyone of you have a Speedpart's strutbrace fitted on 9000? I have just received it but have problem with fitting it. It seems that the bar is too low and oil cap is on the way. I can only get the bar on if I remove the oil cap, but that is not an option. If you have it fitted, could you please post some pictures that could aid me in fitting it?
    TraSh
    '98 900NG Talladega
    '91 900 Aero Convertible
    aug 2006
    Vaassen, the Netherlands
    I fitted the speedparts Strut brace to my 9000. If you have a turbo model there should be no problems with the oil filler cap. If you haven an atmospheric engine like mine is. You would have to modify the oil filler cap connection to the inlet manifold. I drilled an extra hole in the bracket. to move it towards the bulkead.
  1. [LÖST] Byta ratt från en 9000 cs -94 till en 9000 cs -97
    Av penta72 i forum Allmänt
    Senaste inlägg: 2009-10-10, 15:43
  2. Front Strut/Upright Brace Bracket från abbot. nått att ha?
    Av 9kltt i forum Chassi, bromsar och transmission
    Senaste inlägg: 2005-06-11, 00:38
  3. Vad är det för konstig "strut" som sticker upp på
    Av Sato i forum Ljud och elektricitet
    Senaste inlägg: 2005-01-13, 14:58
