Ämne: In Sweden where to look for Mitsubishi turbo TD04HL-15T?
    okt 2005
    Tallinn, Estland
    Hello everybody!
    I own Saab 9-5 2,3LPT MY2001 and as you all know this car is not blessed with a turbo that works. Garrett turbo has been in renovation already once and is blowing blue smoke again (my neighbours are laughing I guess).
    My question is, besides Blocket and Bildelsbasen, where should I look for used Mitsubishi turbo TD04HL-15T, same as Aero models have?
    Or is it even worth buying a used one, as Speedparts offers new one for little bit more €? Of course there is also the question about oil and water pipes that must be changed.
    I would appreciate if you could also explain the difference between Aero ECU and LPT model ECU (styrbox)? Will it give somekind of advantage if I change current ECU with Aero one, and is there anything to look out when buying a used Aero ECU?
    Hello
    Look at www.sdcc.se , they should have some TD04's from 9-3 and 9-5 in stock.
    okt 2005
    Tallinn, Estland
    Yes I have looked at the SDCC site but at the moment they have nothing.
    Does anybody know whether there is a possibility to get discount from Speedparts for turbos? The price is just too high for me, so any € saved would be a great help.
    Citat Ursprungligen postat av smargus
    You should apply for a membership in STCS of course.
    It'll cost you 350 SEK and will give you a discount between 10% & 40% from Speedparts. Regarding the turbos I think it's 10%.
    Maybe you should try to phone SDCC or send them a mail if their website is not fully updated?
  1. mitsubishi td04 turbo.
    Av kangas i forum Motor och motorstyrning
    Senaste inlägg: 2011-12-01, 21:37
  2. skillnad på Garrett TB2531 och Mitsubishi TD04HL-15t 6#
    Av hellas i forum Motor och motorstyrning
    Senaste inlägg: 2008-10-16, 20:42
  3. Turbofråga Mitsubishi TD04HL-15T
    Av undrande i forum Verkstäder, försäkringar och köpråd
    Senaste inlägg: 2008-06-23, 18:55
  4. Mitsubishi TD04-19T turbo-agg på SAAB 9000 2.0T -86
    Av delta99 i forum Motor och motorstyrning
    Senaste inlägg: 2006-04-07, 20:41
  5. Hur mycket klarar en 9-3 Viggen Mitsubishi TD04HL-15t 5#
    Av SuperFaCeR i forum Motor och motorstyrning
    Senaste inlägg: 2005-09-02, 13:30
