Nää inte riktigt, men det kan bliUrsprungligen postat av 900 Power
(väntar nog på att någon annan agerar försökskanin...)
"Utan tvivel är man inte klok"
Tycker den där verkar rätt intressant.
Som sagt, ingen som vill vara försökskanin?
/Henrik
jag skulle kunna vara det men den passa ju inte till min låda för jag kör en saab 9000 cse
http://www.garaget.org/?car=60355 min nya bil
Det blir bestilt deler fra usa før jul, disse skal monteres i "Gatebilen".
dette er en asfalt-racing bil, så testing blir ikke aktuelt før i april-mai...
Så jeg prøver jeg, men racing med slicks er ikke sammenlignbart med normal kjøring.
til dere som har kjørt på Rudskogen, jeg kjører 1.09 runder med standard 8V T...
APC-meteret står alltid på rødt!
Hvem er mats Damhäck?
Fikk svar fra twinsaabs i USA:
The phantom grip is a pretty simple device. It is two steel plates pressed against the spider gears of the differential with very strong springs.
Since I got the street racing springs, the shop needed to shave about 1-2mm of material off of the spider gears to get everything to fit correctly.
Overall, I'm very happy with the results. It pulls much better out of turns and doesn't spin the inner wheel very much at all now. For the price its hard to beat.
There has been some discussion about longevity. I've had the LSD in my car for 1 year now and it still works okay. I have not had any track time with and I haven't really pushed the car since I got the new tranny.
The rumor is that the steel plates wear down the spider gears and the small metal shavings will ruin the tranny bearings. I took of my rear cover after 2,000 miles and I did not notice any premature wear. The rumor came from Honda folks, so maybe this is true with cheaper Jap steel.
Good Luck!
vad är det som skilljer som gör att en sån här inte passar kortlådorna? skulle det gå att modifiera eller låta få tillverkat nått liknande som funkar till dom?
MVH Lerne
Hm... passar denna i Og900 eller??
Också sugen...
/L-O.
Twinsaabs som Petter 900 t hänvisar till kör väl varsin og900?Ursprungligen postat av larsola
Kolla här: http://www.twinsaabs.com/
För övrigt riktigt bra, & rolig sida, dock minns jag inte att jag läst nåt om phantomgrip där men det var länge sen jag var där. ( om det ens är dom som det refereras till.)
Tja!
Passar denna diffbroms i en 78:ans fyrpet?
Jag har inet fått klart för mig hur den fungerar. Diffar den från start för att sedan släppa vid ett visst moment. Det är ju tvärt om mot hur det skall vara..
Att tillägga är att jag kan NADA om växelådor..![]()
Om den passar min låda så är jag mer än GÄRNA försökskanin..
Daniel
Den ska ju passa og900
Och då borde den ju passa i en kokillåda från 78...![]()
Det är ju inte dyrt om denna skulle funka bra.
Är rätt trött på att bilen vill släppa nu och efter vintern blir det ju mer mos ändå...![]()
/Henrik
Tja!
Ni som har beställt från USA, hur är det med tull och moms?
Vad kommer slutnotan att hamna på?
Närmare 4000:-?
Daniel
Tja!
Jag har hört nån stans att om man skickar grejjer inslagna från en vanlig persons address istället för ett företags address så kan man undvika tull och moms.
Daniel
Ja det kan man.
Iaf har inte vi fått betala någonting när våra släktingar där borta skickat paket till våran familj.![]()
/Henrik
Tja!
Är det nån som vet vad tullavgiften ligger på ?
Jag har tänk att beställa i slutet av Mars och vill veta lite hur mycke pengar som måste sättas av..
Daniel
Får 2 stk. på mandag, 3 jan.
prisen til norge er ca 6000.- for begge inkl. norsk moms.
den ene skal monteres inn i en kokill-låda, som skal inn i Gatebilen.
Bilen er under totalrenovering, og er ikke på veien før i april.
kommer selvsagt tilbake med evt. monteringsproblemer og erfaringer.
Petter
Svar ja...Ursprungligen postat av Andreas Plars
og900 är helt underbara att köra med diff. Inte bara det i starten utan även vid bankörningen, enklarare spårval och ett underbart "driv" ut ut kurvorna. Driver inte lika långt ut i ytterböj utan bilen går det man styr. Sååå skönt...
Ååå, jag veet!! Men nu blir det nästan porr!Ursprungligen postat av MrTurbo
Dårlig bilde, men ifølge USA er dette de 2 første i Europa!
Petter
Hej hur går det med bilen har du fått ut den på premiär tur med den nya diffen?
MVH Tommy
Saab 99 T16, Audi 80 quattro 20V 650hk 740nm.
http://www.garaget.org/mypage/?user=16143
Skulle vara intressant med lite kommentarer om bilen har kommit ut på gatan än?
#3309 Andreas "Dea" Persson
900 Cab -87, 2*900 Aero-88, 900TurboS -92, 9-5 -09
