Resultat 1 till 9 av 9
Ämne: Fitting Saab 900 ecu in an 9-3
    aug 2005
    Is it possible to fit an ecu from an '96 900 turbo in an '99 9-3 LPT (also trionic 5). I know I need a tech2 to connect the ecu to my 9-3.
    Mark
    Hi,
    That will not work in terms of software. Hardwarewise, the two ECU's are compatible, but you will need an appropriate software in the '96 ECU first. My recommendation would be to use the '96 ECU to send to a tuner of your choice and ask them to inject some vitamins into it.
    I assume you're looking for a "quick fix" to get some extra power...
    Best regards,
    KK
    aug 2005
    That's was the idea.
    I hoped i worked, there where some people that told me the ecu should work in an 9-3. They said the ecu's are the same, the difference was in the electronics of the car. The only thing that had to be done was to couple the new ecu with the car.
    What is the difference in software?
    My plans are to first fit a different intercooler, than an 3" JT, than safe money for a Maptun Stage 3. In the meantime the 185HP is to keep myself satisfied.
    Citat Ursprungligen postat av MXL
    I would suggest to mods in this order instead:
    - better intercooler (always money well spent, especially on the NG900)
    - Maptun stage 1
    - 3" JT
    - upgrade to Maptun stage 3 software (will not cost you more than an extra 50 Euro or so to upgrade from stage 1 to stage 3).
    Best regards,
    KK
    aug 2005
    Went to the dealer today with the 900 ecu. Ask them if they could try to couple the ecu to my 9-3, the told me that this couldn't work, in my oppinion it should work, so i asked them to try. After explaining several times that it was at my own risk the did it.
    Ans guess what, it worked!!!
    Now i'm still waiting for my apc solenoid valve, so i still have 150hp, but the ecu works!
    So the only thing that happens, is that the twice reads the serialnumber from the ecu, there is nothing different between the ecu's.
    maj 2004
    Falkenberg/Halmstad
    While on subject,
    KK > Why is it especially recommended för the ng900? To swap intercooler first of all?
    I thought that the Stage 1-tune (whichever-tuner) could run on original hardware?
    mvh Johan Kullberg
    aug 2005
    The dualpass intercooler of the 900 and earlier 9-3 has a terrible airflow. In practise this means that the air that comes out of the intercooler is warmer. Upgrading your car with a new ecu (stage 1,2 or 3) means that more air under higher pressure will flow through the IC, this air comes out really hot, and enters the engine really hot. This will result in poor performance and a hotter engine.
    You can use a stage 1 with the original IC, but it is better to upgrade.
    maj 2004
    Falkenberg/Halmstad
    I know how the IC works, but I didn't know that the original one was so poorly coolant. Thanks for the reply MXL.
    mvh Johan Kullberg
    Växjö
    I would go for the Nordic Stage III from start..... probably the best program on the market for that car...... (and yes, change the IC)
    Veteranaren: BMW 525 E12 -75
