Resultat 1 till 7 av 7
Ämne: Stereo and rim, tyres size
    nov 2017
    Luleå
    Which stereo for a 900 og do you recomend. Also wichs size and preassure of rims and tyres do you recomend for a 900 110HP. I live in a rainy area and I am looking for easy to steer, fuel economy and safety. Dont care about big boots.
    Regards
    Steg 3 Mr.Os avatar
    nov 2004
    ja
    Citat Ursprungligen postat av darwinland Visa inlägg
    I would follow the recommendation in the owner´s manual. I dont have it, if you dont have it either, just get back.
    §99CC74900T81,§9000T86,§9-5 03,†9-5 02,§9-5 02, *9000Aero 95, *9-3 04, *9-5 09,*9-5 09
    White,Svart,Odoardogrå, Silver, CosmicBlue, CosmicBlue, LeMansBlå, LaserRed, Laserröd, CarbonGrey
    nov 2017
    Luleå
    YEah I have it, checked it and found it 2,0 2,1
    Steg 3 Mr.Os avatar
    nov 2004
    ja
    Excellent! But actually thoose are the min values. It is recommended to add .2-.3. so in the range 2.2-2.5 is fine
    "If everything else fails read the manual"
    nov 2017
    Luleå
    so 2.2 2.3 or 2.3 2.5 will be the best for fuel economy and safety?
    Steg 3 Mr.Os avatar
    nov 2004
    ja
    Well, you have the manual. The pressure is different for different tyre sizes. But if you just use .2 or .3 more than listed in the manual it is fine. Which tyre size do you have?
    Since you live in Luleå the cilimate changes from hot summer to cold winter means big differences in temperature. This affects the tyre pressure, so it is a good advice to check it monthly. And in snowy conditions low pressure results in better grip. (and increased fuel consumption)
    nov 2017
    Luleå
    Ok I understand, thank you for the wise advice.
    I am using 185/60. I guess is the best wide size for this car, perhaps if you drive with 175 you can get better comsumption.
  1. Size på rattmuttern? 9000
    Av daspunner i forum Utseende och styling
    Senaste inlägg: 2016-01-20, 14:44
  2. Byta stereo i en 9-3 -01 till stereo från en 9-5 -01?
    Av gororn i forum Ljud och elektricitet
    Senaste inlägg: 2015-11-07, 19:11
  3. Byta Cd stereo till cd/bandar stereo
    Av LinusStolpe i forum Ljud och elektricitet
    Senaste inlägg: 2014-05-08, 11:00
  4. FULLWAY TYRES
    Av rickard1987 i forum Chassi, bromsar och transmission
    Senaste inlägg: 2012-10-19, 07:38
  5. Ratten skakar, hjälp någon? [size=18][color=red]Fixat!!![/co
    Av Club_Maccan i forum Chassi, bromsar och transmission
    Svar: 12
    Senaste inlägg: 2006-08-14, 13:27
