Resultat 1 till 6 av 6
Ämne: TTiD oil control light NG9-3
    apr 2018
    Hello i am from Poland and i don't know Swedish language.
    I have a problem with my Saab 9-3 TTiD, oil Control light appears on a half of seccound after car starting when she is cold.
    maybe therw is such topic at your forum but i dont know how to try to find it. link will be enought, i can translate this with using google translator.
    In January I have changed o'ring between oil pump and hose (oil pressure low informatorom has appearing)
    I will be grateful any help.
    Regards
    Damian
    Hi Damian,
    Is it the O-ring for the oil pickup you have replaced? Part.Number: 93167112
    http://www.schwedenteile.de/images/93167112_o-ring.png
    http://i.imgur.com/vAWbioL.jpg
    apr 2018
    Yes, that one
    apr 2018
    is there a possibility to find parameters/conditions in which thats lights?
    then you could measure all those parameters and try to notice which one is out of the limits in the moment when light appears.
    Senast redigerat av damirac den 2018-04-23 klockan 22:26.
    I have looked at my red "oil can" control light when starting the TTiD engine latest days. It keeps showing it self for approx 2 seconds after the engine starts running after cranking & approx +10 deg.C outside. I have Mobil 1 ESP 0W-40 oil in the engine.
    mar 2018
    I'll just throw this out there, is the car maybe sitting on an angle while parking? So that the oil is not hitting the sensor for a few seconds until it starts to flow.
    Just a thought...
    Sent from my SM-G930F using Tapatalk
  1. ESP unit control
    Av itsee i forum International SAAB related talk
    Senaste inlägg: 2017-10-24, 20:59
  2. Skillnad TTiD -08 och TTiD -11 119g
    Av gucpm i forum Motor och motorstyrning
    Senaste inlägg: 2012-01-21, 23:59
  3. Är det Lamp Control?
    Av acidflash i forum Ljud och elektricitet
    Senaste inlägg: 2008-11-18, 16:25
  4. TCS Control
    Av Skoogis i forum Motor och motorstyrning
    Svar: 17
    Senaste inlägg: 2008-07-01, 20:12
