Resultat 1 till 5 av 5
Ämne: Problem with Saab 9-5 Biopower
    nov 2017
    Hi guys, well im not new to Saab and i love it, but recently i bought 9-5 biopower 2007 and i feel like its really heavy when starting and it loses a lot of fuel same time like 18 on E85-100km and 13-100 on 95,i have changed air fillter, oil and oil filter, plug spark too, still the same and i have even cleaned up the MAF fillter or Mass, any idea what could be wrong with it? the only part i bought but didnt change is the fuel filter becuz i couldnt locate it. any idea about it i really love it but it costs me alot of fuel.
    thanks for all.
    The fuel filter is underneath the car, right next to the fuel tank. I don't believe that is your problem though, as a leaky filter will leave spots on the ground and the car will stink.
    I think your problem has to do with broken return valves or vacuum hoses. Inspect all vacuum hoses and check all return valves for function.
    Air leaks cause the Trionic system to believe that more fuel is needed (and it is) so the car starts to use a lot of it to compensate. If it's a BioPower car, the leak has to be very big before the Check Engine light will show up.
    Steg 4 Frals avatar
    But a 9-5 biopower have no filter under the car as petrol 9-5. It's just the filter at the pump.
    /Fred
    Nu VW Passat Sportscombi GTE 218hk/400Nm 2017
    Tidigare BMW 320d Xdrive Touring Sport 184hk/380Nm 2014, BMW 320d Touring 184hk/380Nm 2011
    Ännu tidigare SAAB 9-5 SC 2,0t BioPower Nordic st1 ProPerformance 2006.
    Steg 3 Mr.Os avatar
    So, you should consider returning the filter since it is not for your version of the 9-5. Especially if it was recommended by the store.
    feb 2018
    If it's possible to return it you should - Else you should see the mechanic (unless you think you can do it yourself) - If you found the problem, it would be interesting to know
  1. Saab 9-5 Biopower Xenonljus problem
    Av Ahlgren88 i forum Ljud och elektricitet
    Svar: 19
    Senaste inlägg: 2016-01-13, 12:00
  2. Saab 9-5 biopower 2,0 problem ingen ork.
    Av Nexus i forum Motor och motorstyrning
    Senaste inlägg: 2014-09-28, 16:59
  3. Diverse problem, SAAB 9-5 biopower -05
    Av andreas.w i forum Motor och motorstyrning
    Senaste inlägg: 2014-02-20, 14:50
  4. Saab 9-3 1,8T Biopower. PROBLEM!
    Av Chrilleen i forum Motor och motorstyrning
    Senaste inlägg: 2011-08-27, 09:42
