Resultat 1 till 3 av 3
Ämne: Brake Upgrade 9-3og/900/2
    sep 2015
    Hello,
    I need some guidance as to where to find caliper carriers for the 345mm discs. Upgrade to 308 already happened but has proven to be not good enough for track days. Any lead would be highly appreciated.
    Greetings from Germany and mvh (not mbH - bloody autocorrection on IPhone...)
    Andreas
    Senast redigerat av elwood.jake den 2017-05-03 klockan 11:17.
    sep 2016
    I'm not entirely sure here, but I think Speedparts.se used to sell conversion kits to make the Turbo X brakes fit.
    9000CDE 2.3t -95 | 9000CSE 2.3T -95 | 9-5 Aero -03
    MR2 GT -94 | Evo IV -96 | LS400 -91 | KE35 -78 | RS2000 -92 | Scirocco GT -77 | E28 -86
    Och lite motorcyklar etc...
    Hi Andreas and most Welcome to STCS
    I don't know what pads and brake fluid you are using but those will also have impact on the performance.
    Using racing fluids will require more frequent changes but that's usually not a problem on a tray day car.
    Fluid with both high wet and dry boiling points are recommended and usually more expensive e.g. Castrol SRF.
    ATE Racing Blue is an alternative less expensive.
    Ferodo DS2500 or DS3000 is a good upgrade option and Carbotech XP8 or XP10 are another often used pads.
  1. OG900 upgrade
    Av Javier de Andrés i forum International SAAB related talk
    Svar: 0
    Senaste inlägg: 2012-05-31, 20:31
  2. OG 900 Trionic 5.5 upgrade
    Senaste inlägg: 2012-05-28, 22:15
  3. Kopplingsbyte/upgrade OG-93
    Av SaabKillen i forum Chassi, bromsar och transmission
    Svar: 23
    Senaste inlägg: 2006-04-25, 20:40
  4. as1 upgrade till min 9-5a
    Av Henke_Vector i forum Ljud och elektricitet
    Senaste inlägg: 2006-03-24, 14:14
