Något har troligen gått snett igen (ämlans skräp...) jag skall kolla (jag har problem med min apparat med pyttemjuk fönster...)
Problem med pyttemjuk apparat är aldrig roligt
Har projektet stannat av?
2015/01/27 09:45:18.463 connection with a server has been closed
2015/01/27 09:46:30.551 the job is processed
2015/01/27 09:46:30.551 a new job from server received
2015/01/27 09:46:30.551 started processing the job
2015/01/27 09:46:30.566 successfully connected to server
2015/01/27 09:46:33.281 processed job has been sent to server
2015/01/27 09:46:33.281 connection with a server has been closed
2015/01/27 09:46:34.497 the job is processed
2015/01/27 09:46:34.497 a new job from server received
2015/01/27 09:46:34.497 started processing the job
2015/01/27 09:46:34.513 successfully connected to server
2015/01/27 09:46:37.181 processed job has been sent to server
2015/01/27 09:46:37.181 connection with a server has been closed
2015/01/27 09:48:07.489 successfully connected to server
2015/01/29 10:11:50.577 application is started
2015/01/29 10:11:50.655 successfully connected to server
2015/01/29 10:11:52.917 connection with a server has been closed
2015/01/29 10:11:52.917 no jobs from server
2015/02/03 10:58:28.814 successfully connected to server
2015/02/03 10:58:31.064 connection with a server has been closed
2015/02/03 10:58:31.064 no jobs from server
Har vi gett upp helt?
Kommer snart ha en hemma-server som kan stå och arbeta 24/7 om så krävs. Lever projektet?
Eftersom Bollman inte svarat på snart tre veckor så gissar jag att projektet självdött.
NSA har nog skickat Bollman till Guantanamo
Argh! Jag saknar windows-kraft så jag har inte kommit åt servern på länge, jag skall se om jag fixar det ikväll!
Har projektet dött så kanske tråden kan avklistras då den ju knappast har allmänintresse.
Stay tuned. Det kan hända mer. Jag har en programmerare som tittar på programkoden för att ge oss ledtrådar!
OK, jag har stängt ner det mesta av mina men du säger väl till om projektet vaknar till liv med samma klienter som innan.
Yes, jag lovar att säga till när kraften behövs igen!
om det är någon annan som vill köra något så får ni väl säga till.
Kan tyvärr inte hjälpa dig med g|adp0rr men kan skicka över några svettiga disketter med tysk leder/schnurrbart-porno...
Nu är jag ju lite sen men rullar projektet? har lite mhz att dela med mig av :-)
mvh Thompa
"Snabbast i hamsterhjulet - är fortfarande en hamster"
Saab 9-5 Aero original 2007 av kulören skumsilver
Bollmans projekt lär inte snurra.
Vet inte om Procedomani fortfarande vill få fatt på g|adp0rr från Vitryssland men det är nog rätt troligt. Fråga honom!
Skall denna tråden verkligen vara klistrad?
Projektet har väl dött för denna uppgift.
Nä, det skall inte vara klistrat, och är inte så längre och faller snart in i den digitala glömskan
