Resultat 1 till 7 av 7
Ämne: Turbo choice?
    okt 2004
    UK
    Turbo choice?
    Hi all,
    What's a good choice of turbo for the 9000 2.0ltr?
    Looking for power around the 350hp mark
    mar 2004
    Västervik
    Garrett GT28BB
    TD04 18 or 19T
    Mvh T.Thilly
    RABIATMOTOR
    Which model year 2,0 turbo?
    I assume you intend to run it on stock manifold, therefore my question.
    Best regards,
    KK
    okt 2004
    UK
    MY is 1996, yes with stock manifold.
    Steve
    Citat Ursprungligen postat av Steve-UK
    I'd look at a TD04HL-18T #6, which is a hybrid turbo. Basically a Volvo -18T but with a Saab #6 turbine housing. Pretty much bolt on, using 9000 Aero water- and oil lines.
    Another option is a T28BB, which is fully bolt on using your stock water- and oil lines. 350 hp is a stretch, but perhaps possible.
    To really make sure you hit the 350-mark, there are two nice little Garrett GTBB's available: GT28RS (Garrett spec. 350 hp) and the slightly bigger GT2871R (Garrett spec. 400 hp). Both these will bolt on to your stock manifold but will, naturally, require custom water- and oil lines. For optimal function, I would also recommend a custom downpipe that takes full advantage of the 3" outlet on the GTBB:s.
    Also, these two latter would probably work best in conjunction with slightly hotter cams, e.g. 262/9,5 or similar. Custom software is also a must of course, but I assume you are aware of that.
    Best regards,
    KK
    jun 2005
    Finland
    Hi all,
    Citat Ursprungligen postat av DarkRaver
    Garrett GT28BB
    TD04 18 or 19T
    Anyone know whats the difference between GT28BB and GT28R ?
    Or is it the same turbo?
    STCF #7
    Citat Ursprungligen postat av ng900t
    Anyone know whats the difference between GT28BB and GT28R ? Or is it the same turbo?
    As far as I know, it's the same turbo. ATP refer to it as GT28R (which is the official Garrett name), whereas most Swedish tuners for some reason choose to call it GT28BB.
    Best regards,
    KK
  1. Svar: 26
    Senaste inlägg: 2008-05-19, 11:34
  2. Skillnad på turboaggregat Volvo vs. Saab
    Av David_9000cse2,3t-96 i forum Motor och motorstyrning
    Senaste inlägg: 2005-09-08, 23:13
