Sidan 1 av 3 123 SistaSista
Resultat 1 till 20 av 44
Ämne: Biltema 52-200 Fuel pump
    Hi to all,
    Sorry for English language, I just don't speak any Sweadish. I'm from Finnish Saab Club, and as I know, some of you have experience in Biltemas 52-200 fuel pump.
    If you have/had this pump, please could you tell how many kilometers are/was behind?
    I would like to know some statistics about this fuel pump "quality". In Finland many people prefer walbro copy pumps instead of cheap Biltemas pump. I have inside this 52-200 but only maybe 5tkm behind, and have nothing bad to say. What about you people?
    Btw, Thank you for Saab and Abba.
    Steg 5 Mackans avatar
    50000km without issues so far, have also been running mostly on e85.
    ///Mackanized
    Tillbaka
    Borensberg
    Re: Biltema 52-200 Fuel pump
    About 100 000km in my Old 9-5 before it was sold, probably half of it on e85.
    apr 2005
    I just ordered the "skruvat" complete unit... Will install this weekend. Will that pump take E85? I will save the old unit, and if it fails prematurely I can use the biltema instead. What kind of hoses did you use? I took the complete unit, as I been told it was a pain getting the pump and hoses get right in the unit...
    Äger fn. ingen SAAB.
    Tech2 och CombiAdapter
    Annat bilinnehav: Renault Zoe -19, Volvo V70 -05, BMW Z3 -99, VW 1957, VW Karmann Ghia 1960. Tidigare bilar: VW 1302S 1972, VW 1950, 1962, Golf SC 2014,-16,-17,-19, Passat GTE- 20
    aug 2006
    Blekinge
    Citat Ursprungligen postat av risig9000
    If its the same that BDS sell it does not work with e85.
    The plastic hose came lose after just one tank of e85.
    /Mattias
    9-3 Aero 02
    9-5 Aero 06
    apr 2005
    Citat Ursprungligen postat av mattias claesson
    /Mattias
    Suck, vilket skit, jag har ju tanken full av E85... full tank - 10 liter... Vad göra nu då... den är redan skickad till mig... puh... köpa pump från biltema då... vilken slang ska man köpa då tro?!? Behöver man "knorren" som säljs på skruvat m.fl.? Eller duger annan slang? Har hört biltemas löses upp av utvändig bensin. Orkar inte klabba för mkt med detta...
    apr 2005
    viewtopic.php?f=3&t=269890&start=25
    Citat Ursprungligen postat av pgot
    Hej, BENSINPUMPSBYTE angående allt prat om slangar som inte tål bensin..... Bytte Bensinpump på min 9000 2,0t -97 för en tid sedan, nippel dia 8 i nya pumpen (från Biltema) och dia 6 i bef slang förstås. Men pillade ut befintlig nippel ur trasiga originalpumpen utan att ta bort slangen från nippeln, lät nippelresterna sitta kvar i slangänden (som invändigt stöd) men sågade av utstickande nippelstump.
    Köpte och satte sen (efter tips under letande i andra diskussionsforum) dit ett 4cm långt Svart Plastbränslerör som skarv, dia 12/9 Det används i t.ex. Scania Lastbilar som bränslerör, tål därför bensin in och utvändigt för det är ju homogen plast. Trädde först över slangklämmor från OK, sen plast-röret utanpå slangstumpen 2cm in, och sen på nya pumpens nippel, och drog åt klämmorna rejält både över nippeln och över slangänden.
    Hur enkelt som helst och detta håller garanterat!!
    Lycka till, slangen finns såklart hos Scania, och Volvo + alla som reparerar eller servar tyngre fordon! även FESTO slang av typ PAN funkar (dimension i så fall 12x1,75 dvs 8,5 invändigt)
    Jag som inte sett innandömet där detta ska ske, betyder ovan att man kapar pumpens nippel och bara byter precis delen som går in i pumpen?
    Någon som har närbild så man vet vad man har att vänta. Jag vill helst införskaffa ALLT innan jag river detta... när pumpen är borta så står ju tanken helt öppen... kanske nåt man kan täcka för med som tål soppa?!?
    Scaniaslangen låter ju inte fel, kanske kan hitta den på jobbet... vart sitter den?
    Sitter här och trodde jag gått lätta vägen som beställt armaturen komplett, men alltid ska detta piratskit strula... Nu vågar jag inte sätta in den... hade jag inte haft tanken full med E85 hade jag kunnat svälja det och fortsättningsvis bara köra på bf95...
    aug 2006
    Blekinge
    Du får väl ta en titt på förpackningen om det är samma som min "Masterpart 33-2785". Pump nr 2 funkar fortfarande, men nu med 98 såklart. Vet ej om den första var ett måndagsex. Det är slangen som går ut från pumpen som lossnat. Dra dit en slangklämma och hoppas?
    /Mattias
    9-3 Aero 02
    9-5 Aero 06
    apr 2005
    tackar, ska kolla när den kommer!
    ok så slangar har inte löst upp sig eller pumpen gett upp? Kan det vara ojämn kvalitet och inte med E85 att göra? Verkar ju otroligt konstigt om den inte klarar en tank E85 när det trots allt börjar vara mycket etanol i standard soppa...
    Jag ska nog även ta och leta rätt på en slangbit samt köpa en biltema pump. Är det lätt få dit den, så blir det ju isåfall mer pålitligt. Ville just slippa krångel och köpa en armatur. Men är de så kass så är det ju bättre gå på den beprövade.
    Grundladd virrgots avatar
    När det gäller slang, åk till Hydroscand, dom har billiga och bra!
    9-5 B235E+ fd. 900Aero-84
    apr 2005
    Fått hem skruvat pumpen, "proffessional parts sweden 23342785" står på den.
    Sökt och sökt inte hittat nån lämplig slang som nån hade hemma...
    Blev denna;
    http://www.gatesunitta.com/en/gates-fue ... 225-series
    Gates har en som enligt spec ÄR nedsänkbar, men den hade ingen hemma och fanns inte per metervara heller... (4219 verkar den heta, http://www.midlandvehiclecomponents....lletin_043.pdf)
    Frågan är ju om den jag har (3225) håller. Såg sedan en tråd som rekommenderade hydroscand 1432-50
    Finns många trådar om detta, men ingen som riktigt bottnar det... bla
    viewtopic.php?f=18&t=327259&p=2212348&hilit=gates# p2212348
    Vad ska man chansa på tro? Skruvat armaturen? Gates 3225 i gamla armaturen?
    Vänta och köpa slangen på hydroscand? Beställa dränkbara gates?
    Ingen som vet hur länge gates 3225 håller i E85?
    viewtopic.php?f=18&t=289237
    apr 2005
    "proffessional parts sweden 23342785" tål enligt dem själva EJ E85. Tur jag inte installerade den.
    Huruvida GATES 3225 tål bensin/E85 på utsidan vet jag inte än, mer än att den tål det iallafall mer än de få timmar som vissa fått problem efter. En provbit i en burk samt en slang i tanken, sen i lördags.
    feb 2006
    Torpshammar
    vad är det som du menar inte tål E85? Pumpen du har köpt är väl en komplett armatur och de har vad jag vet plastslangar på alla ställen istället för gummi?
    MacGyver Mr_SunBears avatar
    Mälardalen Västerås
    Citat Ursprungligen postat av StefanM
    Troligen delarna/materialet i själva (elektriska) pumpen är inte utprovade med E85 därför kan de inte garantera funktionen. Men det är en gissning.
    //Björn
    Björn #3471
    Västerås
    Instagram: mr_sunbears_garage
    Köpte en armatur från skruvat och satte den i en etanolkonverterad 95 m04 höll 4 veckor sen låste pumpen sig.
    Slangarna därmot ser fina ut.
    apr 2005
    Citat Ursprungligen postat av Mr_SunBear
    //Björn
    Det är de själva som säger pumpen ej för e85.. Jag väljer att ej prova...
    Mälardalen Västerås
    Bytte själv till en Henkopump för ett par veckor sedan. Köpte denna Gates slang på AutoExperten. Den är klassade enligt SAE 30R10 och ska klara Bensin/E85 mm på både insida och utsida.
    Länk till slangen: http://www.autokatalogen.se/afw/vastera ... No=1663154
    //B
    Björn #3471
    Västerås
    apr 2005
    //B
    Den var förfärligt dyr tyckte jag (300kr för 30 cm, ok om man kunnat köpa de 3cm man behövde) - dessutom fanns den inte hemma i fredags. Jag var tvungen att göra bytet då nämligen då jag hade mer att laga på bilen jag behövde lyft till och hade fixat tid för att göra de jobbet.
    Min billiga GATES slang har börjat färga bensinen den ligger i brun. Låter bilen stå några dagar medan experimentet fortgår. Försöker nog få fatt på en slangbit på hydroscand i nitril på utsida och se om jag kan byta i helgen, om den verkar upplöst då. Med mindre soppa i tanken och vanan inne går det nog på under en timme...
    okt 2007
    Stockholm/Huddinge
    finns det någon annan slang som inte kostar 300kr (!) som är lämplig att använda? kommer bli mycket E85 för mig.
    SAAB 9-5 2,3T Ecopower Vector -02
    ErikssonR och risig9000, ni kan väl dela på en 30centimetare?
  1. Är det samma Ventilpaket på en TCS pump / ABS pump ??
    Av xor i forum Chassi, bromsar och transmission
    Senaste inlägg: 2006-07-13, 16:07
  2. 9-5 Bio Fuel
    Av kolera i forum Allmänt
    Senaste inlägg: 2005-08-29, 16:56
  3. Saab Flexi Fuel kit?
    Av sjpilis i forum Motor och motorstyrning
    Senaste inlägg: 2004-12-21, 10:38
