Resultat 1 till 15 av 15
Ämne: roofspoiler
    roofspoiler
    hello.
    Can someone who has fitted a roofspoiler on the 9-3 tell me this:
    how can you fit it and STILL KEEP the 3rd brake light and washer jet/nozzle?
    I have seen a blue viggen or 9-3 with this, but the roofspoiler is made for ng900 with no brake light at the top of the hatch/tailgate???
    tack! Thanks!
    2002 9-3 SE "turbo anniversary"
    Nordic stage 3+ (automatic)
    231 HP/ 255 FT-LBS torque at last dyno
    Steg 3 Pelles avatar
    Skåne
    Hi,
    I don't have any direct answers to your question
    but the car on the pic you posted belongs to a guy who hangs around here.
    His nic is WoX and here is his profile.
    http://forum.saabturboclub.com/phpbb...profile&u=4953
    Send him a pm with your question if he doen't find this thread.
    Cheers
    Pelle
    Citat Ursprungligen postat av Pelle
    Hi,
    Cheers
    Pelle
    I have made it a little bit better...
    my english sucks but i can tell you that it is NOT easy to made it fit
    // WoX
    Varför Aero när det finns Viggen
    Citat Ursprungligen postat av wox
    // WoX
    Ok, can you tell me what you did to make it fit?
    your english seems great! I am sure I will understand the idea.
    or if you can tell me in Swedish maybe someone can translate for me?
    Växjö
    Hey Abdukted!..
    The thing is, you need to really carve alot out of the spoiler. It doesn't leave you alot of material left. in addition to that you need to grind the top of the brakelight aswell. Still, it might not be enough clearance to open the rearhatch fully. So it's alot of work, that may pay out. The easiest way is to throw away the brakelight.
    Veteranaren: BMW 525 E12 -75
    Hi Mike!
    I think in the USA maybe it is required to have the third brake light?
    maybe a LED custom light that is slim and will fit... but what happens to the washer nozzle/jet that is part of the brake light?
    Växjö
    Citat Ursprungligen postat av abdukted1456
    Hi Mike!
    Plug it.. hahaha... do you really use it?... I know I don't....
    Yeah, a custom LED light might be the answer. There's alot of aftermarket lights that will fit from the inside of the rear window...
    do you need to disconnect the fluid from the nozzle somehow? where will the washer fluid go? into my trunk?
    Växjö
    LOL...
    I'd disconnect the pump... so it won't pump any washerfluid... prob' the easiest way....
    do you know where the pump is for the back? different than for the front? I still use the front washers!
    Växjö
    It seems to be the same pump as for the washerfluid in the front.
    I'd then just cut the hose going to the rear and direct it to pump back into the washerfluidcontainer... that way it won't matter how much or how long it pumps... it'll just go round and round..
    maj 2004
    Falkenberg/Halmstad
    It'd also be pretty McGuyversome to connect the rear fluid-hose to the front washernozzles ... to get that special "Siffreidi"-nozzleeffect that the ladies like so much
    Maybe it's possible but a bit tricky, I don't know.
    mvh Johan Kullberg
    Thanks for the help, Mike!
    Växjö
    NP..... glad to help...
