Resultat 1 till 8 av 8
Ämne: saab 9000trionic wiring
    Hello all, I'm looking for some help in saabs home country.
    I own saab 9000aero MY95 with trionic 5.5, ets, tcs, vss, apc
    I need to run b234r with trionic in other car, i don't need ets, vss, evap, tcs.
    And my problem is: Is it possible to turn off ets, vss, evap and tcs in trionic, or i have to find wirings from 900ng trionic without ets and vss?
    At this moment i have:
    -b234r+ecu and whole wirings from mentioned aero
    -dp and exhaust 3'
    -inlet piping 2,5-3'
    -standard throttle body 65mm from 900ng
    -ic from 9000 aero
    -hx35w
    need to buy:
    -map sensor 3Bar
    -injectors 630/850 cc
    -fuel pump walbro255/bosch 040/44
    -gauges
    -wideband
    And here are few pics of my ride:
    http://<a href="http://www.fotosik.p...&#91;/img]</a>
    Östersund
    Re: saab 9000trionic wiring
    Citat Ursprungligen postat av menzuramenzura
    Yes, it´s possible to turn this things off
    nov 2009
    Karlstad
    Sweet ride, is it a Lada ?
    Yes, it´s possible to turn this things off [/quote]
    So I won't have to search and buy simpler wirings of 900ng, I may stay with my 9000 wirings? Thats good news.
    There is some strong saabs with over 400 and 500+HP here in Poland, but most of them are 900ng and so their wirings are rather good known.
    And it's not lada, its fiat 125p
    http://www.classics-the.com/grupy/te...-1976---Tomekk
    nov 2009
    Karlstad
    Aha ! My bad. It's gonna be a beast with the B234R . How much power are you aiming for ?
    Östersund
    [/quote]
    You turn this functions of in the software with T5Suite, so you can stay with your 9000 wiring harness.
    Excellent excellent.
    And about target power-about 400HP
    arrangements:
    -pressure 1,5Bar
    -max RPM about 6500
    I hope it's enough to reach 400hp, and I also hope standard camshafts and timing, and head with its flow won't be a barrier
    You would benefit from using a 9000 wiring harness without ETS. If you stick with the ETS-harness, it will have to be modified.
    BR
