Resultat 1 till 2 av 2
Ämne: rebuild T7 engine
    rebuild T7 engine
    hi, i'd like to renew my 1999 T7 engine and I have some parts out of my T5 engine (pistons camshafts and so on)
    can I use these things (they say that the T5 engine can handle more power because they used better pistons back in these days)
    Uppsala
    Re: rebuild T7 engine
    hi a very late reply,
    use the crank, pistons and the conecting rods from your T5 engine.
    The T5 camshafts have a more aggresive nature then the T7 cams.
    But remember to change your software if you use the T5 cams, and also if you do not want to lower the top of the pistons by 1.1 millimeter then you must use T5 headgasket.
    Plenty of people myselfe included have used T5 parts for up to around 500Hp
  1. Tyda "rebuild-skylt" kortmotor
    Av Ken-1 i forum Motor och motorstyrning
    Senaste inlägg: 2009-05-16, 00:29
  2. Engine Flush
    Av Pette i forum Motor och motorstyrning
    Senaste inlägg: 2006-12-12, 14:37
