Resultat 1 till 2 av 2
Ämne: Uprated pressure plate needed! OG9-5
    Well, as I have already told you, on my Viggen/9-3og projekt car, my pressure plate is sliping from the 4th gear and above (mind you I have 6 speeds) from 3.000 RPM up (
    Now I need an uprated 9-5og pressure plate, to hold up to 600 Nm. Specifically one for 9-5og, since I am using a hybrid clutch (9-5og flywheel + pressure plate & 9-3SS clutch/friction disk).
    I know someone who was not very happy with Spec Stage2 and GT30 (the pressure plate exploded!!!), and the Sachs Race Engineering pressure plate that I have from Racestuff is soo hard that I can barely press the clutch pedal (
    Result=> no go for street
    What are the other options? I know AP RACING also makes clutches compatible with Saab 9-5og, anyone has more details on this route?...
    Thanks for recommendations!
    __________________
    Lucian (from over the Ocean) / Saab brum-bruum
    join me: http://www.facebook.com/profile.php?id=790889050
    aug 2005
    Re: 9-5og uprated pressure plate needed!
    Hello!
    A new 9-5 Aero pressure plate and Maptuns SPEC plate holds 550-600nm
    Opel Astra J OPC 2012
  1. Oil pressure, translation, help
    Av IceSaab i forum International SAAB related talk
    Svar: 14
    Senaste inlägg: 2007-11-19, 20:48
  2. IC, bar & plate vs. tube & fin
    Av Fredrik / 1941 i forum Motor och motorstyrning
    Senaste inlägg: 2007-08-15, 10:24
  3. Looking for Saab number plate-holdings from sweden
    Av familie.behrendt i forum International SAAB related talk
    Senaste inlägg: 2007-02-02, 22:47
  4. Intake Manifold Pressure
    Av Ingo i forum Motor och motorstyrning
    Svar: 34
    Senaste inlägg: 2005-07-25, 16:00
  5. Validation sticker for License plate.
    Av Tweek's Turbos i forum International SAAB related talk
    Senaste inlägg: 2005-07-21, 00:19
